Hello Jack,
When you disconnect your camera, do you use the "Safely Remove Hardware" utility in Windows? Are you using Windows XP? What camera are you working with?
In the past, I have encountered problems where the driver association in Windows caused similar errors. Even after unplugging the camera and uninstalling all of the software, Windows will maintain information about the camera and driver. The most thorough solution is to reformat the computer, but this is also the least desired solution. Another method I have used is to delete associations in the Windows registry.
I do not advise manually editing the Windows registry unless it is absolutely necessary. Please use extreme caution, as your system could become unstable if the wrong keys are edited/deleted. First, unplug the camera from the system using the "Safely Remove Hardware" utility. Next, open the registry editor by clicking Start>>Run and typing "regedit" (without the quotes). Browse to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\1394". The registry keys in this folder are specific to the 1394 devices installed on your system. If you are certain that the camera is unplugged, then it should be safe to remove the key specific to the camera. In the attached screenshot, I have only one 1394 device installed, a Sony camera. To clear the association with my camera, I would delete the folder named "SONY&CCM-DS250_1.07." Before I can delete the folder, I have to right-click on it and change the permissions to "Full Control." Once deleted, you can close the Registry Editor.
Before plugging the camera back in, you should also delete the contents of the Data folder located at "C:\Program Files\National Instruments\NI-IMAQ for IEEE-1394\Data". This will remove the camera files that the IMAQ driver created. When you plug your camera back in, it should be very similar to when you first installed it. You will need to open MAX and change the driver to the "NI-IMAQ for IEEE 1394 IIDC Digital Camera" driver.
Again, please use extreme caution when editing the registry. If you would like, you can create a service request and call in for support. One of our IMAQ supporters can assist you with this process. Otherwise, let me know if this helps out.
Best Regards,
Jesse D.
Applications Engineering
