Measurement and automation explorer
In my application, I want modify the offset and the sensitivity in scales of Measurement and automation explorer. Is it possible to do it in a VI and how?
Because in my application I have a menu in which there is a calibration part. In this, I would like to group all parameters of my sensors (name, sensitivity and offset) and write automatically the offset and the sensitivity located in Measurement and Automation explorer without quit my application.
Thanks for your help,Franc.
(2,537 Views)
There might be a way to do this with DAQmx, but DAQmx is not supported in LabVIEW Real-Time 7.0.
Using Traditional NI-DAQ, you can only read custom scale information with Get Scale Information.vi. This VI is located under Data Acquisition >> Calibration and Configuration >> DAQ Channel Utilities.
(2,537 Views)
