Measurement data is not stable Crio
Dear
I am quite new with using Labview, and I have different problemes.
The hardware I use is a Crio with 9125 module
The biggest problem I have is that the measurement data is not stable, see the XLS file within the zip file.
an example: We have a calibrated transfo, the output is constat 10 Volt out for 250V input, The current here is 230V. So the output of the transfo is like 9,2V
When I mesur this signal with the CRIO , I get values like 9,2 V and then couple of second later it drops tot 7V, gets back up tot 9,1V for a while, than it drops again.
So the signal is realy not stable for the CRIO, but when I mesure with a other devices the signal is continuous like 9,2 Volts so its a problem with the CRIO of the VI.
I think I made mistakes on the VI, so i putted this within the zipfile.
Does anyone know what I am doing wrong?
Thankx
Second thing that I dont know
How can I run this VI without the help of my PC? Now I must connect my pc to the CRIO to let the rio mesure, and my files that I save, are saves on the hardisk of my PC en not on the RIO
Thanks a lot
Message 1 of 1
(2,355 Views)
