Measurement of frequency using NI-9401 and NI-cDAQ
I am new to using the DAQ assistant. I want to measure frequency of 1Hz over a period of 32 seconds using NI-cDAQ and NI-9401. I have done the following configuration, but it gives an error ' -200284'.
Any lead on how can we measure frequency over a specified period?
(1,592 Views)
Hi Chetana,
Did you read the error description? It mentions something in the lines of "timeout settings"…
General recommendation: don't use the DAQAssistent, use the DAQmx API instead. It's easier than you might think!
(1,590 Views)
The error description says, 'Timeout occurred before some conversions got complete'.
I wanted to measure a signal of 1Hz over measurement period of 32 seconds. I am confused with the settings to be done.
Any leads on how to configure for my case?
(1,564 Views)
Hi Chetana,
The complete message is:
Some or all of the samples requested have not yet been acquired.
To wait for the samples to become available use a longer read timeout or read later in your program. To make the samples available sooner, increase the sample rate. If your task uses a start trigger, make sure that your start trigger is configured correctly. It is also possible that you configured the task for external timing, and no clock was supplied. If this is the case, supply an external clock.
So what is the configured timeout value?
Is there a sample clock?
All we got so far is an image of one of the configuration tabs of the DAQAssistent. You know we cannot edit/run/debug images with LabVIEW!?
(1,555 Views)
Thanks for your reply @GerdW.
I am attaching my VI here.
Any issue with the configuration?
My input is a digital signal of 1Hz frequency.
(1,530 Views)
