Measurements with EtherCat chassis in FPGA mode
I am trying to find out if there is possile to carry out measurements at 100KHz using NI9144 EtherCat chassis with a Real Time computer. I am using the NI9215 modules to measure voltages. Some example FPGA codes use DMA FIFOs but as I saw in the Forum are not available for NI9144. Could you suggest any feasible way to aquire the data ?
Thanks in advance
(2,622 Views)
Hi TapTap.
You are correct: You cannot transfer data from your EtherCat chassis using DMA. Instead, you need to use User-defined Variables. The following guide shows you how to setup your chassis, and how to communicate with it.
Setting Up EtherCAT on NI Programmable Automation Controllers
Also, make sure you have installed both the NI-RIO driver and the NI-Industrial Communications for EtherCAT, and make sure you have the correct versions.
NI-RIO and LabVIEW Version Compatibility
NI-Industrial Communications for EtherCAT and NI-RIO Compatibility
After you have installed the correct software, you can find some examples: Launch LabVIEW, go to Help => Find Examples. In this windows navigate to: Hardware Input and Output => NI-Industrial Communications => EtherCat. You can for example have a look in the FPGA folder.
I hope you can use this information.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(2,585 Views)
I have already set up the communication with the proper software. This difference with cRIO and Ethercat about the UserDV, got me in troubles since I am not so familiar with EtherCat. I will check the examples you suggested. Thanks 🙂
(2,582 Views)
