Measures of Mean bug
LabVIEW 2011,
C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\gmath\statdist.llb\Measures of Mean.vi
Mathematics\Probability and Statistics\Measures of Mean.vi
In documentation:
percent (trim) specifies the total percentage of outlier data to trim when computing the trimmed mean. LabVIEW trims half of percent (trim) from the lowest values of x array and half from the highest values
The code inside obviously shows, that it trims double value. Be carefull!
(2,997 Views)
I agree the documentation is wrong and should be changed. The VI is fine.
(even the icon of he trimming subVI shows full percentages, not half)
(2,982 Views)
I agree. It trims the percentage specified from both the upper and lower outliers. I've filed CAR #341627 to have R&D correct the documentation.
CLD Certified
(2,941 Views)
