Measuring 10Amps with Keithley DMM6500
I've a Keithley DMM6500. In manual mode the current measurement works and I know, that the 10 amps range is not included in automatic range selection.
Current goal is to use the rear 10 amps input for current measurement with Labview but I haven't figured out where to select this 10 amps range in / from Labiew. Any hints?
Thanks in advance.
(1,823 Views)
Accepted by topic author beato66
Hi beato,
@beato66 wrote:
Any hints?
Read the (programming) manual of your DAQ device!
It will explain all the SCPI commands you need to use to actually do that measurement…
I recommend chapter 11&12!)
(1,793 Views)
We already read in the manual, but didn't succeed with the driver.
In the end there was a bug in another VI...
Thanks again.
(1,735 Views)
