Measuring Pressure with LabView
Hi there,
I'm using two CET9000 OEM pressure transducers which are connected to an NI USB-6009.  I'm very new to LabView and I'm wondering what would be the easiest program to recognise the DAQ card and graph the pressure drop across the two transducers on LabView?
Thanks!
(3,104 Views)
With LabVIEW, you've already got the easiest program. If you installed DAQmx, the card will be recognized and you can use the DAQ Assistant or the lower level DAQmx functions directly. There are numerous examples that come with the DAQmx installation. Give some of them a try.
(3,098 Views)
OK I'll give it a try, thanks!  Hopefully I won't have to talk to you again! 🙂
(3,080 Views)
What kind of output do your pressure transducers provide?
(Sorry, I could not find the CET9000 specifications. did you mean CTE9000?)
(3,054 Views)
