Measuring RTDs (NI 9219) and Full bridge pressure sensors (NI 9237) simultaneously
Dear all,
I am new to labview as a lastminute part of a small project. I have found multiple topic regarding a similar error. which all come down to something to do with hardware of software clock. However I just do not understand the problem.
So I was trying to make a program so I could use the cDAQ-9172 with a NI9219 for two RTDs and the 9237 to measure two full bridge pressure sensors. I first created a own program which did not work. To get more understanding I tryed to merge the labview library examples which than gave the error above. I copy pasted the code together and it has something to do with the Hardware clock and software clock I just do not understand how to solve it.
Apologies if i have read over a topic regarding this
Best regards
(1,386 Views)
Accepted by topic author JanMM
You can start only one AI-Task on an cDAQ-9172:
cf. page 20 of the manual:
https://www.ni.com/pdf/manuals/371747f.pdf
Combine your two tasks into one.
Regards, Jens
Kudos are welcome...
(1,342 Views)
