Measuring a temperature by thermocouple
Hi, I'm a PhD student in energy mechanics field, I would like measure ambient temperature by using labview and NI-9213 DATA acquisition, everything is okay but when I hit run I alaways obtain weird results the amplitude statrs from 2200 over time instead of 23 or 24 °C
Who can help me please? I'm really lost
waiting for your answers
Message 1 of 18
(2,939 Views)
Please share the code you use to acquire the temperature data from NI 9213.
Santhosh
Soliton Technologies
Message 2 of 18
(2,905 Views)
How can you say that "everything is ok" if you get the wrong result??? 😮
(The value of indicators in edit mode is completely irrelevant.)
There are millions of ways to get the wrong reading and dozens of ways to do it right. To narrow it down you need to show us your code and also explain how things are physically wired up.
Message 3 of 18
(2,901 Views)
I meant that everything is well wired beacause i've already seen a video on youtube of how to measure a temperature using a k type thermocouple by a NI data acquisition
here is the code and the material that I use
Do you please have any idea on  the source of the problem ?
Message 4 of 18
(2,866 Views)
Here is the main code because i've tried many orthers :
I am using a K type thermocouple look at the picture below
by the way the reference of the module is 9213 whereas the reference of the chasis is 9179 is that a problem ?
Message 5 of 18
(2,863 Views)
  • Photographs of the diagram are NOT "code"!
  • In rare cases, we can tell from a photograph what's wrong, but typically not. Definitely not here!
  • Once the entire code is "baby LabVIEW" (all express VIs and dynamic data) we cannot tell anything because we don't know how the express VIs are configured or what kind of data is in the wire).
  • Does it work correctly in the test panels?
Message 6 of 18
(2,840 Views)
No, it doesn't work correctly (as you can see the amplitude is up to 2000
tell me what do you need to know exactly?
what's a code ?
In my knowledge a VI is to build a project a kind of project using daqmax in the block diagram
(I didn't follow any type of course in labview it's all myself education)
Message 7 of 18
(2,813 Views)
We don't have nearly sufficient information to tell what you are doing wrong.
@chakib77 wrote:
what's a code ?
That would be your file named "203.vi". Please attach it! (Note that I don't have any drivers installed and thus cannot look at the configuration of your express VIs but others might be able to help).
Message 8 of 18
(2,808 Views)
what's a code ?
@altenbach did not ask you if your program worked correctly. He asked if the data acquisition worked correctly in the Test Panels (these are in NI-MAX, not LabVIEW). Furthermore I cannot see that the amplitude of any values is up to 2000 in anything that you sent. I see a picture of a blank waveform chart with amplitude from 150 to 2500, but that doesn't tell me anything. I would recommend that you at the very least take a look at https://www.ni.com/en-us/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-ha.... It would be beneficial to also review some of the training material at the top of this forum.
As altenbach has said your code is your vi. If it's in a project then include the entire project. A picture of a vi is virtually useless in most cases (and especially in your case).
Message 9 of 18
(2,787 Views)
You're not helping me here .. anyway thanks for reading me
Message 10 of 18
(2,767 Views)
