Measuring and recording strain gauge data.
How can I measure and record strain gauge data using the following hardware:
DAQ 6071E, SC2043 (Strain gauge), SC2070
and LABVIEW.
It appears that the Vi in the DAQ example, continous strain meaurement.vi does not provide a recording capability. Is that true?
Is is it possible to combine it with other VI to be able to record the data?
Thank you
(3,197 Views)
Foudah,
All you need to do is add the function "Write to Spreadsheet file" from the "File I/O" subpallet. There are two ways to do this. In the first example, a row of readings from multiple strain gauge measurements is appended to a text file every time the loop executes. The first time through the loop, a dialog box will appear asking for the file name as nothing is wired to the "filepath" terminal (you could wire a control), a shift register handles each subsequent execution of the loop.
In the second example the readings are gathered into a 2D array at the loop boundary and all sent to a file at once.
Hope this helps.
(3,197 Views)
