Hi pyrochk247,
Out of curiosity, are you using a motion controller to control the motor, or are you using the 6024E's counters to do the PWM? We don't deal with Back-EMF as a method of feedback so you'll have to forgive me if I trip up my understanding of the topic:
In the way of reading the motor windings for a simple voltage and feedback voltage, that is highly possible. Using a 6024E card you would be able to read in the analog signals and use the counters as outputs at the same time. What would be difficult about this is pulling out the Back-EMF signals from the standard motor winding voltage. I found this article:
http://www.acroname.com/robotics/info/articles/back-emf/back-emf.html
So the trick would be developing a method good enough to read the signals we desire well and rejecting the rest. If you are using PWM from the 6024E then you could do decent feedback to the motor through a PID loop.
Currently, I'm not trying to suggest anything. Rather, I'm asking to see if this idea makes sense to you.
Let me know what you think.
Justin Louie
