Measuring distance between points
Hey,
I am trying to do 2-D particle tracking.  What I am trying to do is for each point in the image, I want to find the shortest distance to anouther point. Repeat for each point.  Then move on to the next image and then compare those distances, since the particles are moving slowly, to help keep tabs on the particle.  So for example if it was at least 15 pixels away from the nearest particle in picture one, that should stay about the same in picture two.  However I am having trouble trying figuring out how to find the closest particle to every particle.  I am open to other suggestions as well for 2-D particle tracking.\
(3,266 Views)
Hi novastar15,
What software are you using to process the images?  NI Vision software for LabVIEW?
Thanks!
Megan B.
(3,228 Views)
hi there,
i wrote a little vi (see attachment), but ist not tested.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,213 Views)
I got something that appears to be working but not the most efficent piece I have ever done.  The vi you posted looked good.  And I am  using the vision package to find the centers.  Though it appears I need to refine that some more since over the course of a 30 second video all the centers go missing at least once.
(3,197 Views)
