Measuring frequency of digital signal through SCC-DI01
I have a PCI-6251M Series and SC-2345 with SCC-DI01 installed.  The input signal is a TTL pulse train from an encoder (360 pulses/revolution). I am trying to measure the frequency of this signal and convert it into an RPM measurement.  All the examples I have found regarding frequency measurement use the built in counter which does not allow me to choose the input signal (di0) from the SCC-DI01 (must be a physcial channel...)  I have connected the TTL input into CTR0, and using some of the examples I could get a frequency reading.  Why can't I do the same using the SCC-DI01?  Because the SCC-DI01 is optically isolated I feel more comfortable usign it than having inputs wired directly to the 6251 CTR input.
Using DAQ assistant, I have the data from SCC-DI01 di0 (boolean) signal manipulated (DDT) into a binary stream (0 and 1 output).  Using the Signal Timing and Measurement function results in an "inf" frequency reading.
I'm sure I'm missing something very trivial, but thus far have not been able to find a solution.  NI support helped getting the frequency measurement through the counterCTR0, but not through the SCC-DI01.    I'm using LabView 7.1 (have not installed 8.2 on new PC yet), and relatively new to LabView. Thanks in advance for any help.
(2,520 Views)
Hi mwoz,
You cannot measure the frequency of a TTL pulse train on a digital input, you can only measure the frequency on a counter input.  The SCC-DI01 is a digital input module.  If you feel more comfortable using the SCC modules because of isolation and you want to measure the frequency of a pulse train, then you will need the NI SCC-CTR01.
I hope this helps, please let me know if you have any other questions!
Erik J.
(2,494 Views)
