Measuring humidity using DAQmx
Hi
I have a few question regarding the measurement of humidity using labview.
First of all I should say i'm a beginner and I am not too familiar with labview, but this is something that needs to be done.
I'm using a HIH4000 humidity sensor (3-wired) and a USB-6008 DAQ device.
The problem is that i'm not sure how to configure the DAQmx.read block in labview to be able to measure relative humidity.
I've measured temperature before (when configuring the read block, temperature one of the options to choose from, while there is no 'relative humidity' option).
That's about it, if you need more information i'll share it with you asap.
Thank you!
(4,662 Views)
The 6008 can only read voltage. So, read, scale, display.
(4,652 Views)
have you tried to measure voltage?
Then you can count a relativy humidity from sensor range, maximum voltage and actual measured voltage.
Simyfre
(4,642 Views)
Thank you for your fast response!
But how exactly I scale the measured voltage?
(i'm sorry if i'm asking stupid questions, but as mentioned, i'm pretty new).
(4,640 Views)
Relative humidity [%] = Range [%] * Actual voltage [V] / Range [V]
Simyfren
(4,634 Views)
You scale it according to the formula that is in the data sheet that comes with the sensor - so many volts per relative humidity. Attach the data sheet if you don't understand it. The basic math functions (add, multiply, etc.) can be used with scalars, arrays, waveforms.
(4,628 Views)
Thanks you guys again for helping me out!
Here is the datasheet:
HIH4000 datasheet
(4,622 Views)
