Measuring linearity error using LabVIEW
I am aquiring linear data (voltage Signal) with respect to time, from a 0-5V sensor using PXI-6251 DAQ card. Is there a Built in VI node in LabVIEW to measure the Linearity error? I came across nodes for fitting regression lines, but not linearity error. How do I do it?
(3,687 Views)
Which linear regression VI are you trying to use?  The Linear Fit VI under Mathematics/Fitting has an output called reside which should be the measure of linearity, i.e. how well the data fits the linear regression line.
(3,683 Views)
Thats great, but will the error value correspond to integral or dynamic nonlinearity? Will it be in % ?
(3,680 Views)
