Measuring loop and trigger
I have two palallel loops, first loop for signal generation and second for measuring generated signal (graph). Measuring loop is triggered to start with DAQmx trigger. My problem now is loop doesn't stop at all. timeout for "DAQmx read" is set to infinite because loop should wait input signal for long time. Is it somehow possible to force the loop stop.  I use local variable to stop parallel loops.
Any help really appreciated.
-Simo
Message 1 of 1
(2,565 Views)
