03-05-2007 06:50 AM
03-20-2007 06:25 AM
05-09-2008 11:28 PM
Hello there,
So can we use the code in http://zone.ni.com/devzone/cda/epd/p/id/513 to work with USB6210 or what changes do we have to make in it to measure the frequency of an application. The application is changing frequency from 10 Hz to 2500Hz.
I used USB6008 for measuring the frequency of an application. And am not getting good results, recently got USB6210 and was hoping if there is any example for measuring the frequency using USB6210.
05-10-2008 10:50 PM
Hello there,
Was just reading your thread and was thinking if its possible to use the code in http://zone.ni.com/devzone/cda/epd/p/id/513 to work with USB6210 or what changes do we have to make in it to measure the frequency of an application. The application is changing frequency from 10 Hz to 2500Hz.
05-10-2008 11:04 PM
05-10-2008 11:41 PM
thanks Dennis for your prompt reply. Will this example work with USB 6210 ? I am thinking of using USB6210 instead og USB 6008 to measure the frequency of my signal.
Thank you once again.
05-11-2008 12:02 AM
I know you are trying to use the 6810. You mentioned that in both of your posts above.
Do you see the 'Requirements' box in the example finder? It says right there what hardware can run the example.
