Measuring time for loop to execute once
I have a state-machine-like structure and another while loop within the case structure. This while loop executes, by my approximations, about every 500ms, but I want to know the precise time.
How do I measure the time that a while loop consumes to execute exactly once?
I've seen this done with a sequence structure, but unfortunately I don't know how to do it with a simple while loop.
Thank you,
Alex
(3,277 Views)
How about this?
Message Edited by Ravens Fan on 07-24-2008 01:33 PM
(3,275 Views)
And if you want to measure over several iterations :
Message Edité par JB le 07-25-2008 08:51 AM
(3,247 Views)
By using the attached VI, you get a solution that needs less work (assuming you are using the error cluster wire) and is therefore very fast to implement.
Message Edité par JB le 07-25-2008 08:59 AM
(3,245 Views)
