Measurment of water lever in a tank.
As I said before, thanks for all the help. This a preparation for a laboratory task.
I can't really figure out what you mean by define dx for the chart, have been searching a lot for it but can't seem to find it. I've done some changes to it so I will attach the new code.
Message 11 of 18
(1,265 Views)
Right click the chart and pick Create Property Node.   Select XScale then Multiplier.
Message 12 of 18
(1,262 Views)
Accepted by topic author kalwet
@kalwet wrote:
I can't really figure out what you mean by define dx for the chart, .
We are talking about the multiplier that correlates the point spacing with actual time. With 200ms, the spacing is.0.2, giving you five points for each second.
Message 13 of 18
(1,255 Views)
Some more comments:
With unusual limit settings, it is possible that both comparisons returns TRUE and you'll sends two commands in parallel (We cannot tell which occurs first).
A safer way is to use the sorted values for limit testing.
Message 14 of 18
(1,252 Views)
So more like this then? I still get a red dot for the "Wait". Also if i plug in max and min in the chart as I have done they should display as straight lines, right?
Message 15 of 18
(1,245 Views)
You get a red dot at the wait because your constant is I32 while it should be U32.
(Posting by phone, cannot look at your code)
Message 16 of 18
(1,229 Views)
Still a bit too much code. You only need one case structure and one "power supply" write.
Here is a draft:
Message 17 of 18
(1,213 Views)
Thank you! So if im understanding it correctly the selector decides what to do with the power supply? So for example, if the tank is not full then its false and the selector chooses to start the power supply wich starts the pump?
Message 18 of 18
(1,198 Views)
