Measurments and automation explore does not see Agilis usb connection
Additionally when the agilis connected controller is seen on the screen(green light - see atached) the VISA interactive control doesn't see agilis and all the errors are the same - previuos reply I made a mistake with attachment -it shouldn't be there the green light on the agilis controller byr red one(disconnected)- I hope so you know what I mean Smiley Happy
Message 11 of 30
(1,949 Views)
You get this error if you try to open a VISA session to a serial port that has an existing open session from any application, including Hyperterminal or Measurement & Automation Explorer (MAX). This is not a VISA limitation, but a characteristic of serial ports; you cannot open more than one session to the same serial port. The solution is to determine what other application or VI is already accessing the port and ensure that the program terminates or closes its reference before you attempt to use the port again. I'm not sure if Agilis has anything to do with this.
You could try the following step by step process to close an open session to a port:
  1. Put a "VISA Close" VI on a new block diagram.
  2. Right-click on the "VISA Resource Name" input, and create a constant.
  3. Select the serial port you wish to close, and run the VI.
Have a look at the following knowledge base article as well:
Why Do I Get Error 37 When Using Serial Compatibility VIs or Error -1073807246 Using VISA VIs?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 12 of 30
(1,947 Views)
I'm sorry I ignored your other post. Try the whole thing after you shutdown the Agilis connected controller. Only have the LabVIEW program open.
Adnan Zafar
Message 13 of 30
(1,944 Views)
I did. The LabVIEW is running when the agilis connected controller is switch off but still have problem : LabView is running but agilis device isn't changed -parameters which I setup in LabVIEW didn't correspond to agilis device -
Message 14 of 30
(1,926 Views)
I hope you mean that the controller software is off and not the controller itself!
You have way to many windows up on that screen and I don't know what is active or not. Close the controller software, MAX, and LabVIEW. Open one program (i.e. the driver you got from the vendor) and see if you get that error. If you do, close that program and open Hyperterminal and see if you get an error connecting. If you do, the controller program from the vendor is probably still running.
Message 15 of 30
(1,923 Views)
Yes the controller software is off. The LabVIEW programm from vendor is running as you can see on attachment. (PC see the usb connection and MAX also). The command from LabVIEW does not correspond to my device.
Message 16 of 30
(1,904 Views)
What if you close down the LabVIEW program and just open up MAX. Now, open the VISA test panel. Are you able to talk to the device? If that doesn't work, close it down and try Hyperterminal. Let me know if that works.
Adnan Zafar
Message 17 of 30
(1,900 Views)
I can open VISA test panel but when I try put some command there it doesn not correspond to my device
Message 18 of 30
(1,895 Views)
I forgot say that I can not find hyperterminal - I know that you send me the path where it should be but there isn't.
Message 19 of 30
(1,894 Views)
Try Start -> All Programs -> Accessories -> Communications.
Adnan Zafar
Message 20 of 30
(1,886 Views)
