Hi All,
I had an app in 6i that was a kind of video editing tool and wanted to
upgrade it to LabVIEW 7. Also in the upgrade process I have Windows
Media Player 9 now.
Problem, I can't get diddle to run.
Specifically, I'm just trying to load an mpg file and get an error. I
run my activeX refnum into a property node and select the currentmedia
property. I then run that into another property node and select the
name property, change it to write and wire in a file path name
converted to string.
When I run, I'm getting an error that says the currentmedia refnum I'm
running into the 2nd property node is a null reference. Doesn't make
sense as all the properties are shown for currentmedia in the 2nd
property node.
Any ideas?
Greg
