Mellers Griot beam profiler
Hi
I want operate  Mellers Griot Spoton CCD laser beam profiler with LabVIEW. They have labview interface (attach SpotOn CCD USB2 ActiveX.vi) but this one call another interface and just calculate the center position. But I want operate the camera with labview and get the intensity array data for further processing.
I saw they an option ( see the attach image) to getMatrix, but i am unable to configure that. Please help me
thanks
(2,839 Views)
Hi Kamalm2,
Reading through the .pdf file you attached it seems like Mellers Griot support using LabVIEW for data capture but not for control. Have you tried contacting them about wether this is possible with their software?
It also says this is compatible with LabVIEW 7.0, what version are you using?
Owen.S
(2,783 Views)
