Memory Buffer Full
HI Everybody, I get an error (please refer to the attachement)
I don't know which will cause this problem. Can anyone please suggested any solution or what things need to take care in order to make this problem will not come out.
William Lee
(3,651 Views)
Accepted by topic author williamlee1982
William,
without the code, we cannot exactly determine the reason for this message.
You should look for excessive use of "build array" and similar functionalities since they are known to create this error by improper usage.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,648 Views)
There are two possible reasons for this error, the second one is "no listeners on GPIB".
Since this occurs with a GPIB related VI, maybe that's the problem (and not the memory).
(3,636 Views)
