Memory Error when installing labview 6.1
I had labview 6.0, 6.1 and RT installed on my PC (windows 2000). I tried to install application builder but I got Error that I have no labview installed, so I tired to uninstall RT, but I was abe to. Then I found out that I can't install or uninstall any of the Labview versions. So I went and deleted the whole NI directory, all the keys related to NI in the registry file, and Labview.ini. Now I'm trying to install labview 6.1, but I'm getting memory error and setup terminates. What can I do!
(2,933 Views)
First, I recommend contacting NI support at ni.com/ask and starting an incident report.
Second, I recommend either restoring your registry from backup, or wiping your system and starting over. I know it doesn't sound like fun, and it isn't, but it is probably the only way now you can guarantee a good clean registry. Alternatively, go through the registry again and make sure all National Instruments and LabVIEW entries are deleted.
In the future, and I make this recommendation to everyone, you should, as a safe practice, make a backup of your registry before you install anything, and also periodically. Archive these and label them with the list of programs installed, or with any new programs that have been installed.
The Windows registry is obsolete,
and complete hopeless when it comes to a stable system. There is no automated backup of the registry to my knowledge. The registry is the biggest source of problems with Windows, followed of course by DLLs (everyone has their own version, and noone's is alike, much less works right.) The registry can be backed up by using "Export" from the regedit program. Backups can be restored with the "Import" function in regedit of course.
Good luck.
(2,933 Views)
Labviewguru wrote in news:5065000000050000004EA10000-
1031838699000@exchange.ni.com:
> The Windows registry is obsolete, and complete hopeless when it comes
> to a stable system.
I don't know about that. It does cause some problems, but it also does
some things to make life a little easier.
I found this out during my brief foray into Linux-land. Installing
applications became a real "roll up your sleeves" event, somewhat different
than double-clicking setup.exe. Made me kind of miss the registry, which
really does keep track of a ton of details.
Yes, it would be better if it backed itself up. It would be better if
every application writing to the registry handled itself responsibly,
including clean uninstalls.
Scott
Rev
erse first field of address to reply
(2,933 Views)
