!!!Memory Leak Error - Help Urgent!!!
I am trying to save a cluster in RT code but when I try to do it am getting "Not enough Memory to perform the Operation" and a message follows it (shown below). Is it due to loading more number of controls in the front panel or it is due to some other reason.
(3,892 Views)
Your issues always seem to be !!!URGENT!!!
From How To Ask Questions The Smart Way :
Don't flag your question as Urgent, even if it is for you
That's your problem, not ours. Claiming urgency is very likely to be counter-productive: most hackers will simply delete such messages as rude and selfish attempts to elicit immediate and special attention.
(3,886 Views)
Yes.. Only when it is urgent and no other way to go I use that tag otherwise I'll spend time and debugg the error myself. Ok I abide to your suggestion. Still am searching for the solution.
(3,878 Views)
I would assume it's the first part of the error message, an error in the parameters.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,870 Views)
What is meant here as "FP.heap"?. I have a very big cluster is it means that?
(3,867 Views)
Thanks mercurio I didn't use the fp.heap while searching.
(3,855 Views)
