Memory Leaks in PDA Palm
I am getting memory leaks left and right when I try to run a program compiled with the PDA modual on the Palm. I have found that "Delete from Array" causes memory leaks, however I still get them and I can not get rid of them.
(3,754 Views)
I could not find anything on the issue on the website. Can you strip the VI down to just the problem part and post the code?
(3,754 Views)
Have you updated your PDA module install to 7.0f1? A leak involving Delete From Array was fixed in that patch, specifically when the output array is left unwired and the deleted portion is used instead. Hope this helps.
(3,754 Views)
