Memory/Speed of Split 1D array vs Delete from array
OK, I made a stupid mistake in the last post. I removed the case structure, which removed the timing dependency. I used the 8.6 auto cleanup tool, so I didn't even notice it.
Here's another version (8.0), this time hopefully more accurate. In this version, both reshape and delete take some time. The others take no time.
Again, I would expect that those two at least could have optimizations for a case like this, but I guess they don't.
___________________
Try to take over the world!
Message 11 of 14
(1,653 Views)
so I've redone my test code and am getting similar results to yours. Now  I just have to make sure my test code is right!
Thanks for all the help
Dave
Message 12 of 14
(1,629 Views)
Yair,
You are running all of the benchmarks at the same time rather than one after the other. I believe the fighting of the processor will screw up the numbers while more than one is running. Once three have finished the slowest (and still runnning) will then get exclusive access of the CPU and will start to run faster. I will generally make sure the individual test run one afte the other.
This image (from the clear as mud thread) illustrates how I do most of my bench-marking.
Ben
Message 13 of 14
(1,625 Views)
You're right. My modification was only a quick one to demonstrate why using a loop is a problem here. That was also the reason for my original mistake.
Ideally, the arrays should be allocated first and then each of the subVIs should be tested separately.
___________________
Message 14 of 14
(1,601 Views)
