Memory allocation problems when reading from 4 serial ports
I have run into a problem when I try to read from 4 serial ports in Labview
4.0.1 under Win95. The serial ports use the same interupt (two and two) and
this results in the memory allocated by Labview increases throughout the
execution of the program, which eventually crashes.
How do I solve the problem
Regards
Frede Lei
Message 1 of 1
(2,989 Views)
