Memory and CPU usage rising
Hello All,
i have vi that get cluster reference as input and select from its controls some control by using property "Controls[]" and Index Array and returns its property out.
Then i use this vi in while loop in another vi.
The problem is that memory usage and CPU usage reachs after some minuts 100%. If i delete using Index Array, problem desappears.
Look example of this VIs.
Where is problem?
(3,717 Views)
The type definition is not included (so, it cannot be executed) but I guess that the problem is related to references. Try to close both (it depends on type, sometimes it must be closed) and obtained after Index Array.
Hope this helps
(3,717 Views)
Thanks.
I closed reference to all controls of cluster after using Index Array and this helped.
(3,717 Views)
Make sure you close any reference you open (explecitly or implicitly).
If you are going to access a control repeatedly, get the reference ONCE and re-use until done.
I have reason to suspect that LV does note release all resources after use. I can not prove this.
I will try to check your posting when I get back to the office.
Ben
(3,717 Views)
Thanks, Ben.
Closing reference of all cluster controls helped.
But i don't understand why the problem occured only if i used Index Array for control refernce obtaining.
Without this, the problem don't exist.
(3,717 Views)
Somewhere along the line I read that that LV is smart enough to decide if an output of a node is used. If not, the code is skipped.
Without the Indexing the reading of control ref would be skipped.
Just my guess.
Ben
(3,717 Views)
