Memory is full due to .NET Object
Hi to all,
I'm using Labview with an external .NET table. I initialize the table and then I update some values of this table periodically (1-2 times for second). After a variable time (20 minutes - 2 hours) I receive the error
The section code is
and the problem is that the parts of code highlighted in red even if they have all the correct inputs at some point they start to give out invalid references.
As you can see from the code I always close all the references, the problem seems to be the high number of references used.
Can someone help me?
Message 1 of 10
(5,789 Views)
I've had similar problems. Extract the references the 1st time you call the function and reuse them instead of extracting them every time. See how that works out. Also, why do you convert the random number to variant?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 10
(5,767 Views)
You could try dropping a garbage collector node in there.
Message 3 of 10
(5,761 Views)
For Yamaeda,
This is an example, in my project is not applicable because labview open at the most 2^20 references.
Message 4 of 10
(5,740 Views)
For Kyle97330,
I tried but it does not improve the situation
Message 5 of 10
(5,739 Views)
2^20 Smiley Surprised How do you manage that?
In some cases, like pasting into Excel, you can select the 'insertion cell' and then send a 2D-array. Is there some similar function here?
/Y
Qestit Systems
Message 6 of 10
(5,730 Views)
2^20 is write in the solution of this https://forums.ni.com/t5/LabVIEW/LabVIEW-Memory-is-full-error-using-To-NET-Object-vi/td-p/3651001
No, is not possible to insert an array and in my case it would not help me anyway
Message 7 of 10
(5,727 Views)
Ah. That's why I suggested caching the ref's, as I did in that thread also, then you wont open 2^20 refs.
The only thing I react to in your code is that the Row-ref is closed directly instead of after the loop.
/Y
Qestit Systems
Message 8 of 10
(5,723 Views)
Did you have any success?
/Y
Qestit Systems
Message 9 of 10
(5,702 Views)
No, at the moment
Message 10 of 10
(5,698 Views)
