Memory issues writing binary files, using a subVI to do all File Handling, topVI, when run normally files are way too large.
Problem writing binary files with LV 8.5. I have one VI that does all the interaction/file I/O and another VI for testing. I find when I run the subVI where all the data reading/writing is happening with break points and single stepping through the code all is OK, but when I run normally the files are much larger than they should be and as well when I close the files I get a error. Any insights?
Walter
(3,712 Views)
Can you be more specific?  What errors do you see?  Can you share your code?
(3,710 Views)
Sounds like you have some fast spinning loop in your sub-vi writing way too much.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,695 Views)
I have been called out of town, will tidy up code and post when I get back.
(3,688 Views)
I found the problem, I was actually trying to close the files twice.
(3,677 Views)
I don't see how this could cause the symptoms you described in the first post.
(It only explains the error on close).
(3,674 Views)
