Hi Rachana,
Its been a couple days with no other answers, so I will try to help a bit.
I do not own a PDA so I can not test this myself.
Can you put together a stripped down VI that uses queues that demonstates the issue?
Another thing that I have seen in LV RT on cFP2XXX's is the nature of the queues elements themselves.
Let me explain:
If the queues element is a cluster for example, you could have a string as part of the cluster. Since the string size could be different for different queue elements, the memory storage req's can change. I have also noticed that once new memory is allocated to accomodate an increased storage requirement it is not given up (without starting all over).
I admit this does not answer your question directly, but that is
all I have to share at the moment.
Trying to help,
Ben
