Memory usage on Intensity Graph
Hallo!
I'm looking for someone who can help me to minimize the memory occupance used for the representation of the Intensity Graph. My problem is that I want represent a very big amount of data on a single graph. I put on it a matrix U16 of a (10k x 10k) size or more.
Is there a way to represent this picture optimizing the visualization whith the monitor resolution? Obviously when you Zoom in the specific data must be retrieved in some way. My idea was storing the data in a file an then retrieve only the interested data, but I'm afraid to go on a labyrinth of problems.
Many thanks for your help!
Neon
(3,838 Views)
There exist a NI-day wich answerd to the problem of big array.
I have download this pdf wich could help you from the "Ni-day" page.
bye
(3,821 Views)
Many thanks, for your help!
It's like I believed, but it's much more difficult to decimate a 2D-array...
c-ya
Best Regards
(3,813 Views)
Thanks for the plug, ien_fr. You may want to check out the updated version of that PDF. Search for “Large Data in LabVIEW” at the main ni.com page or try this link.
To get back to the subject at hand, neona is correct. It is more difficult to decimate a 2D array. If you want zooming capabilities, decimation makes your life more difficult, since you need to redecimate every time you change your zoom factor.
You have a couple of options for decimating a 2D array. First, you can implement a 2D version of the max-min decimation algorithm fairly easily. Your decimation chunks will have both X and Y extent determined by the pixel dimensions of you intensity plot area. I am not sure you will be happy with the results, but it should only take a couple of hours to try. Go to the link above and modify the decimation routine to use 2D arrays instead of 1D. You will need to create a double loop structure instead of the currrent single loop structure currently used for 1D.
Second, recommended, you can leverage the enormous amount of effort put into this problem by the image analysis folks. Your 2D data set is the equivalent of a grayscale image (2D array of values). Find a library of image manipulation routines (e.g. Image Magick - http://www.imagemagick.org/), call from LabVIEW to do the resize, then plot the result to the intensity graph (or picture control). You can make the call to the image manipulation routines using either the call library node (for DLLs) or the System Exec.vi for command line utilities.
Good luck. If you find a good solution, please post it so we can all use it. This subject comes up every once in awhile. Thanks!
(3,801 Views)
