Menu Position on TPC-2012 (LabVIEW Touch Panel Module)
Hi
Windows CE on the TPC 2012 places the menu on the top but the LabVIEW Touch Panel Module 8.2.1 places it at the bottom. I would expect that LabVIEW handles that the same way than the operating system?
Alex
(4,986 Views)
And additionally, I don't have a window title for applications built with the Touch Panel Module on the TPC 2012. Is this the normal behaviour?
Alex
(4,979 Views)
Yes it's normal behaviour that you get no window title for the applications, which you've built with Touch Panel Module.
due to the Menue , which Menue do you mean? The menu of the VI or of the WinCE  window? I only know fullscreen VI's on the
touch panel.
Can you make a screenshot of the menu on the top and bottem, which you mean?
Christoph Strasser| AE NIG
(4,925 Views)
Here are screenshots of a LV Application and and of an explorer file view
(4,914 Views)
It's normal , that the menu of the Touch Panel Modul is on the bottom. Since LabVIEW PDA 8 native menus were moved to the bottom
Here is a link, which discusses also this menu position
Christoph Straßer| AE NIG
(4,889 Views)
