Menu events in SubVIs
Hello...
I am using a dynamically loaded subvi, that is displayed in a subpanel in my
main.vi. Now I want to fire events in the subvi by using the custom menu in
the main.vi. How is this possible, for the event case I can only select
<This VI> as the event source, how can I get the main.vi menu as the source
for the events.
PS: I´m using Labview 7.1
Stephan
(2,614 Views)
You can have an event structure in the top VI detect the menu selection and fire a dynamic event or a signaling event [like Value(Signaling)] to trigger the event in the subVI.
You will need to do some extra programming for this (pass the data to the subVI).
___________________
Try to take over the world!
(2,604 Views)
