Menubar by Editing ini file
Hi All,
I want to bulild VI that dispalys Menubar [Header] and submenus on front panel.This all is done through reading \ parsing one *.INI file.
In future user will edit only *.INI file for adding or removing menus \ submenus [User will not modify VI code].
Please suggest where i can get such sample VI code. Guidlines are also very needful.
Thanks regards
Tushar
(2,774 Views)
But what's your problem?
You mentioned:
1 - Read from .ini
2 - Parse this file
3 - create the menu
For points 1 and 3, labview has some examples.
Can you be more specific!
Software developer
www.mcm-electronics.com
PORTUGAL
(2,768 Views)
You might want to start with the Dynamic Insert Demo.
Open Help->Example Finder, Select the Search Tab, and keyword 'Menus'.  Then select the Dynamic Insert Demo.
For LabView 8.5 with normal installation it is located here.
C:\Program Files\National Instruments\LabVIEW 8.5\examples\general\menubars.llb\Dynamic Insert Demo.vi
It will show how to dynamically add menu items to your runtime menu.
How you handle the .ini is a matter of preference.
How you respond to the menu selection is dependent on what you want to happen with the menu selection. (Launch a program, open a window, etc.) But a good start for that is also on the Example Finder, select the Menu-Selection with Events example.
Jon D
Certified LabVIEW Developer.
(2,755 Views)
