03-18-2009 12:04 PM
03-18-2009 09:41 PM
03-18-2009 11:23 PM
HI
Check you keyboards both Alt key, I think that was get pressed and not released properly.
Because this kind of problem happen if your Alt key is pressed.
Hope this helps
Regards
Santosh
03-19-2009 02:17 AM
Exactly!
03-19-2009 12:34 PM
I was hoping that was it, but it is not. I can right click just fine in any other program, and any other program the menus work fine. I also hooked up a new keyboard and mouse and the same thing is happening. I also can not use keyboard controls to do anything. For example alt+F does not highlight the File menu.
LabView is definately behaving as if a button/key is being pressed constantly, but I can't figure out where it's coming from.
03-19-2009 04:52 PM
If a different mouse and keyboard did not work, it still does seem like a corrupt installation of LabVIEW. I would refer to the attached document to ensure that a clean re-install of LabVIEW is done. I hope this helps.
