Merge 3D Stem Plots
I need to combine the two 3D Stem graphics (for comparison), setting them a different type of display (circles and squares). Not switch between them using the Plot ID. But simultaneously the values of the two graphs.
Above, I gave some graphics and tried to use set_plots.vi, but it only takes values from conventional 3D control.
Below, made through the usual 3D control, it works, but not satisfied with the lack of lines like in Stem (need a histogram).
(3,798 Views)
Accepted by topic author Nick_Chirkov
You can use indocator's property node
(3,784 Views)
Thanks! You helped me a lot! (от души спасибо, я сидел пол дня)
(3,779 Views)
