Merge two TDMS files
Good day
 Have been trying to find a way to merge 2 TDMS flies created using Sound and Vibration assistance one is the acceleration and the second is the frequency.
I would like to be able to port to Excel to present the data.
Thank you
Jay
(5,463 Views)
Do you have the TDMS Excel Plugin?
aputman
(5,458 Views)
Yes but how will that help me with the merging of the files?
Jay
(5,431 Views)
Jay
It doesn't.  I was addressing your second statement about porting the data to Excel.
aputman
(5,429 Views)
Couple of options.
https://forums.ni.com/t5/LabVIEW/Rearrange-TDMS/td-p/2449740
https://forums.ni.com/t5/Example-Code/Programmatically-merge-all-TDMS-files-contained-in-a-folder/ta...
Basically a simple command line copy operation will do it.  Perform a command line call like the following:
copy /B File1.tdms + File2.tdms NewFile.tdms
(5,426 Views)
