Merging Multiple VI's
Hi, I am working with GW-Instek GDS-820 oscilloscope. I have downloaded instrument driver from the manufacturer website. I simply want to merge different VI's to control different functions of oscilloscope. For example VI for voltage measurement and VI for waveform display are different. How to merge both VI's? I am new to labview and need simple solution (I have already tried Merge Tool).
Message 1 of 14
(3,976 Views)
You have much to learn about LabVIEW before we can give you a meaningful answer.  You might want to check out this link.
Bill
CLD
(Mid-Level minion.)
Message 2 of 14
(3,969 Views)
But any advice that could help?
Message 3 of 14
(3,968 Views)
Given your inexperience with LabVIEW, there's nothing wrong with running them separately.  I think that would be the easiest solution.
Bill
CLD
(Mid-Level minion.)
Message 4 of 14
(3,964 Views)
Actually i am working with labview "Web publishing tool " for online experimentation project. Instead of loading separate VI every time for controlling each function of oscilloscope every time on the client side, i simply want a single VI which includes all the function present in other VI's. Any solution will be helpful. Thanks.
Message 5 of 14
(3,962 Views)
"Simply want" and "simply done" are rarely bedfellows.  You will actually need to code a user interface where you can select what function you want to use and then call the approriate VI.
Bill
CLD
(Mid-Level minion.)
Message 6 of 14
(3,954 Views)
thanks anyway 🙂
Message 7 of 14
(3,951 Views)
@adi51 wrote:
thanks anyway 🙂
Sorry about that.  It's like merging two dlls.
Bill
CLD
(Mid-Level minion.)
Message 8 of 14
(3,949 Views)
This is extremely basic. You just place the different VIs in the driver onto a new block diagram. Wir the error in/out connections to control execution order. There are hundreds of examples that come with LabVIEW. Look at them. Take the tutorials and then post back.
Message 9 of 14
(3,947 Views)
Message 10 of 14
(3,946 Views)
