Merging two plots
I have a simple question, I have two plots right now. I want to merge them into a single plot. I have included the code below, with appropriately highlighting the graphs which I want to merge.Capture.PNG
Is there a way to do so.>??
Thank You
(3,517 Views)
Accepted by topic author sanjeeev
define "merge".
Try "built array" in concatenate mode. (right-click...concatenate inputs)
(3,513 Views)
Thank You very much...
that worked...:):)
by "merge" I meant that I have at present two graphs, but i would like to have both on a single graph not two, that is combine them or merge them side by side such that both are plotted or shown in a single graph.
(3,508 Views)
