Message concern virtual counter in LV 2018
I'm looking for any exampl (" *.vi " in LV 2018 ), which contain simply virtual counter of events (value 0/1)  - as shown in adding example...
If existst such one, give me please its link.
Grizli
(1,392 Views)
I would stay away from dynamic data. You have 100 points per iteration, but are only looking at one element.
Simply count F to T transitions using a shift register. Here is a very simple example using a random square wave.
(1,358 Views)
Dear Christian,
First of all I wish thanks very much for your example, which has ability to count of generating pulses.
But now I would like to use it for possibility to couning the pulses from other
generator (as you see on my attached project) , or from any virtual object generating some evets.
I have tryed connect that elements, but it did not works good. Could you help me
to do it. ?
Kind regards for you.
Grizli
(1,294 Views)
I hope, you have got my message and therefore I'm expested your answer.
Thank you very much for it.
Best regards
Grizli
(1,279 Views)
