Message shows that after running a standalone program
I met a strange problem when start running the program, which is a created installer for 8.5.
The window shows
even I am not using webserver. How to get ride of this issue?
Ott
(4,644 Views)
You say you're not using the web server, but is LabVIEW configured to have it enabled? Check the LabVIEW options (Tools -> Options -> Web Server:Configuration page).
(4,631 Views)
Thanks for infor.
I checked it. The web server config is unchecked, and also the NI server. The issue is still there.
Any thing else could cause it?
Ott
(4,578 Views)
Hi there
Assuming you're talking about an executable created with LV 8.5: In the installation folder of the app there's an <your appname>.ini file. Open that file and compare the web server related keys with that from your LabVIEW.ini file located at ...\Program Files\National Instruments\LabVIEW 8.5
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,569 Views)
Do you mind give more details?
Ott
(4,564 Views)
Accepted by topic author Opt_Ottawa
In LabVIEW all settings from Tools->Options are saved at ...\Program Files\National Instruments\LabVIEW 8.5\LabVIEW.ini
if you create an executable <your app>.exe this .exe has its own ini - file, located at the same direcory as the executable. The name of that ini - file is <your app>.ini. In <your app>.ini you can make the same settings than in LabVIEW.ini.
So if you are talking about an executable: changes in LabVIEW.ini via the Tools->Options dialog does not effect <your app>.ini
Best regards
chris
(4,559 Views)
