Messed up NI Max
Comms to my cRIO are not working in LabVIEW
So I opened MAX - it shows up under Remote Systems but I cannot log in and it shows up as having inconsistent IP settings
I connected via another PC running LabVIEW and all was well with the cRIO. I wandered around MAX looking for clues
. . . . and then went back to my own LabVIEW PC. The biggest difference I noticed was that under My System in Max, it shows No Network Adaptors whilst at the same time it can locate the cRIO
I've uninstalled Max & LabVIEW and re-installed it but still have the same problem
Unable to Log In to the cRIO
I have to use Troubleshoot Remote System Discovery to get this. It starts off with ‘Inconsistent IP settings’
Network Settings appear OK
So why No network adaptors found ?
Message 1 of 1
(793 Views)
