Meter Colors different when compiled
I have an app I put together for a dog and pony show that works fine until I compile it.  It has a meter movement and the colors are a gradient from one side(red) to the other (green) with the red running half way across the meter. The meter indicator has been saved as default, but when I compile, it shows all red.
I struggled to get the colors the way we wanted them and found that using the Scale.MarkerVals[] with the codes for the colors stored in the array of structures works fine in the runtime and I can set the colors any way I want, but this technique is ignored once the program is compiled.
Structure Content
0  -  0,16711680
1  -  700,16711680
2  -  1400,6618880
With the full scale range being 1500
(3,270 Views)
LabVIEW is always compiled. (Do you possibly mean after building a standalone executable?)
Can you attach a simple VI that shows the problem? What is your LabVIEW version?
(I also don't understand your "structure content", Are these the "Scale.MarkerVals[] "? Are these commas? Decimal points? The property should be a 1D array of clusters, each with a DBL for the value and a U32 for the color.)
(3,261 Views)
