Thank you both for the responses, and apologies for the tardy reply - changing priorities, etc, etc, you know how it is...
I've attached a Vi to act as an example for anyone else who has either of these problems.
The main thing I found out is that although you can, as you say, use a constant to "declare" the cluster names for the gauge, these names are only "remembered" by the wire - if you create a local variable of the gauge, it will NOT remember the cluster names. That's what had me confused...
Cheers
Joolz
