Method Not found Exception in VB2013 and LV Runtime 2016
I'm using LV Runtime 2016 to access an exported assembly in VB2013.  When I call the function that uses the DLL, I get the following exception:
System.MissingMethodException was unhandled
  HResult=-2146233069
  Message=Method not found: 'IntPtr NationalInstruments.LabVIEW.Interop.DataMarshal.GetDataPointerWithTDRForArrayIn2(IntPtr, System.Array, Int32, Int32, Int32, IntPtr ByRef)'.
  Source=TestAssembly_alt
Am I doing something wrong with the Runtime?  I looked at the Interop Object in Object inspector but couldn't see the "DataMarshall.GetDataPointerWithTDRForArrayIn2" method...
(3,270 Views)
Accepted by Ben
Figured it out...  The Interop DLL version in the standard runtime installer is 1.0.0.0 and in the runtime installer with DAQmx it is 1.4.0.0...  The 1.0.0.0 version does not have that method...  Don't know why they aren't the same in each runtime installer
(3,229 Views)
*DISREGARD* Figured out my solution
I've been trying to solve my problem the exact same way but using 1.3.0.0.
Was there any particular way you went about implementing this solution?
(1,925 Views)
