Method to count the application execution
Is there any method available to find howmany times the application(.exe) is executed?
(2,800 Views)
Hi there
no, you have to write your own method. The easiest way would be to use the "Configuration File VIs" from the File I/O palette and to increment a counter each time the application has been started. A similar approach would be to save the counter in the registry (Windows only). For that use the "Windows Registry Access VIs" from the Connectivity palette.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,790 Views)
