Method to run a vb script
Message Edité par daniel blanzat le 05-14-2010 09:38 AM
(4,050 Views)
(4,041 Views)
(4,040 Views)
(4,031 Views)
It appears you are having problems posting messages. Most likely it's your web browser. Try a different browser.
Also, please indicate which thread you want the discussion to take place in.
Message Edited by smercurio_fc on 05-14-2010 09:59 AM
(4,026 Views)
Hello, In the atteched exemple, Labview runs a script vbs written in a file via System exec.Is it possible to launch the same script written in a String constant directly in the VI (perhaps using "standard input")?In other words, is there any method to launch a script vbs without used a vbs file?
Thanks a lot, Daniel.
(3,992 Views)
